How do I get my S tablet to be recognise as a pc rather than a phone?
Presumably you're talking about the web browser
If you're using the stock browser in Android 3.2 then it's possible but needs a bit of messing around. One easier solution is to use an alternative browser such as Dolphin HD then change the user agent to desktop
With the 'soon to be released' ICS v4 the stock browser has an easy tick box in it's settings.
I'm sorry but I'm lost here. What are you trying to achieve here?
Hi Sehuxle
Thanks for the advice, I think you are right regards to the browser setting...I'm totally new to tablets but getting used to it slowly. Some webiste I like to get on but it automatically goes to the mobile version which is simplified and its annoying as some of the function not available. I've tried every setting and cant find any thing regards to the this. When is the ICSv4 coming out? Do i need to download the browser? Thanks
Please refer to the post I've left for Sehuxle..Cheers
Don't know what to say about that lol!
Message was edited by: karrhino
