I was hoping the remote control app would come pre-loaded with the remote codes for a Lutron lighting controller.
Whilst there are icons for lighting, there's no options available.
I haven't actually got a remote to learn from - that's a £200+ option.
is there any way of getting hold of & programming the codes?
probably best to ask Lutron themselves..
I Have found these links but not sure if they'll help or not..
links look useful - thanks - but is there a way of entering the codes into the Remote?
may have to dig out my old clie which had some useful IR tools!!
thanks for the support
