Try as I may I cannot get the Reader app to work on my Tablet S 16Gb purchased from Sony Store in Ireland. When I click on the icon I'm directed to the Market to download the latest app. However, it's not available to Irish devices, at least not mine. I don't want the Reader Store, I just want the App. Sony is very clear about this being a feature of the Tablet S in it's marketing on the Ireland website.
Message was edited by: anobrie79
Hi anobrie79,
I've checked & it seems you are correct that the reader app is not available in Ireland..
All I can suggest is that you check the Android Market place I'm sure there will be something available that will work as well as the Reader software..
jus bought a sony tablet myself and having the same problem. also can not connect to the playstation story, theses were both reason I bought the sony tab over other tabs . music and video unlimited also seem to be unavailable in this country, feeling a bit let down.
