could you help me? I have the sony tablet s, my ps store has charged me for the game theam hospital but the game wont download evrey time I try to do this it just comes up with an error what do I do?
go to settings>applications>unknown sources and make sure the checkbox is ticked. that should sort it.
Ed
I have it ticked but it just comes up with an error "(8008102E)" any other way to fix it.
and thanks.
I have brought same thing and have same problem what can I do to sort it have try the unknown program check box but doesnt work? help
I just googled your error code and it shows the ps store as down for maintenance. just keep trying a couple of times a day
Ed
ok thanks mate will do let me know if it gets fixed
thx
I recieved a phone call from Sony on Friday about this same issue - It's still not been fixed, but they are aware of it...
Communication is pretty poor though I have to admit.
Message was edited by: PlymouthFlyer
hi, I am having the same problem, did you find a fix?
I'e had many phone calls and have indeed made many calls but 2weeks on theres no solution and no one seems to have a clue whats going on.
Can't be hard to fix, they've had my money.
same for me to, brought theme hospital from the ps store tgen went to download and error message
apperaed. very frustrating
