After several years of using my tablet I got a problem with closing the USB stub. It lost its function cause of rubber gasket wear. Could you tell where I can order a new stabs for the device?
Hi @X-ray666,
Welcome to the community!
I would suggest contacting your Local support they will be best able to assist with this.
Good luck
