Hi everyone,
Priviledge Plus is no longer working on my Z4. It shows after login "Network error (10011:" . Everything else works fine. So there is no network issue I would know about. The error message is not very meaningful. Is it a password issue?
Deinstallation and reinstallation didn't solve the issue.
Any suggestions?
Thanks and regards,
zampano
It logs fine here, can you go to Settings -> Apps -> Privilege Plus -> Force stop, Clear data, the restart your phone?
Thank you @Quester , that did the trick.
Kudos, Zampano
Glad I could help, enjoy those movies
