I have seen this issue in the past but for different models. Have you tried updating the display adapter drivers?
How can i do that ?
I go to "about tablet" and i click on update and nothing happens...
If you wiped the Tablet itself and ensured you are on the latest software, I cannot see there being much else that can be done to resolve this. From what you have mentioned, that would be something which may need to be looked at.
I have not actually been able to reproduce this on my Tablet so could be a fault. As to what it is causing it, not 100% sure. Have you tried just having the factory install apps on only? It could be due to a specific app which you may have installed.
See if your supplier is prepared to swap it?
Im going to try without no apps of the market only with factory apps to see if happens again...
But in part im forced to use 3th apps to acess the files that i have on the external SDCard...
That is one of a few things that im really disappointed with the software that Sony uses on the tablet...
For now i want to test if is some app that makes this happen...
The tablet was purchased online on Sony website.
If i need to deliver the tablet how can i do that?
You got to remember, Sony did not have to include any software if they wished but some of them are nice to have like the social media and the music player. Some companies just give you the basic Google build and let you do what you want. I always look at it as better than nothing.
As for returning it, I would recommend having a word with the Sony sales division or on your email, they may be contact details from when you placed the order or try using the link below.
http://www.sony.pt/support/pt/contacts/tablet
Keep us updated on how you get on.
I have configured the screen to turn off after 1 minute since yesterday and the screen shutdown more times since i had the tablet, :smileygrin: and so far no problem like i had before. Probably its a program that make that happen...
I only used this:
Avast, File Manager HD Free edition, KingSoftOffice and Mercury Free edition.
This is the only apps that i used nothing more...
One of this apps conflits with the tablet...
On the beninig when i received the tablet i had install this programs and others (not the antivirus) and nothing happened, i can't be shure, but...
Since e decided to use the antivirus it was when the problem started..
I will try without the antivirus..
And thanks for guide me on this Watashiwatesh.
Message was edited by: Fc1975
