Playback
I can not play live TV, videos and Netflix. What could be the problem. This started after the last update. Thank you.
Reproduccion
No puedo reproducir tv en vivo, videos y Netflix. Cual podría ser el problema. Esto comenzó luego de la última actualización. Gracias.
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
uninstall and reinstall the apps, if you experience the same issue after that, then contact the app developers as it's up to them to fix any issues with their apps.
