My Z4 tablet was working great before the latest update to 32.4.A.1.54, viewing TV with molotov app was perfectly fluid. Unfortunately I accepted this 32.4.A.1.54 update and now it's completely jerky. The system update is the only thing that changed...
Sony, please fix this, or tell me how to uninstall this update...
TIA,
Fabrice
J'ai le même problème. Et c'est pire avec canalsat, l'image se fige tout simplement et le son continue normalement. Quelles solutions ?
I have the same problem. And it's worse with canalsat, the picture just freezes and the sound continues normally. What solutions?
GT
I have the same issue in Google play
Heyyy where's the MHL support??? this update has blown away mhl on my tab z4.
I have the same problem, spoke with Sony for an hour last week, also spent 2 hours on the phone with Google as downloaded films/programs on Google Play are now unplayable, constantly freezing etc.
Sony, please sort this out, I have spent a fortune purchasing programs/ films on Google play to watch them on my 3 hour daily commute but can't any more.
Seriously thinking of ditching the tablet via ebay and moving to a more reliable Samsung model
Same to me. Factory reset does not help.
Update has killed Google Play movies, playback is stuttering, unable to watch.
32.4.A.1.54 has left Google Play Movies with the video studder issue, pretty much making my Z4 tablet useless in terms of the major reason I bought the thing. I've tried factory reset and disabling Movie Creator but the problem persists. Sony, I love this tablet but FIX the problem and, if it'd not be too much trouble, preferrably without screwing up anything else.
Same here! Google movies are completely unusable after update. I cleared memory, tried different versions of the app, factory reseted, nothing changed. If this remains I can bin my Z4! And also I won't be buying any Sony android product anymore.
Z4 TABLET LTE, ANDROID 7.1.1, v32.4.A.1.54, PLAY MOVIES VERSION: ANY, COUNTRY:UK
After my LAST exchange with Sony "tech Support", I fixed my z4 problem by replacing it with a Samsung Galaxy Tab S3 and will be limiting my furture Sony purchases to less complex devices.
