Reinstall the latest update with XC and report back.
Alternatives on How to backup Xperias
I'm having this problem too. It reports the battery temp as approx. 50 degrees but tablet feels cool to touch, this is within seconds of a cold reboot too.
It seemed to happen after the 6.0.1 update then it's first charge to 100%, then this problem started. It now doesn't seem to want to accept charge once it hits approx 83%.
Would this be a software probem as it looks like getting these tablets repaired or even getting parts is a nightmare.
Z2 Tablet (SGP521) with dock/charger.
I've removed SD card and SIM & factory reset. Actual battery preformance seems fine, the temperature sensor "spikes" by up to 10 degrees now n then and I think this triggers the warning/shutdown.
Had this as well on an SGP511 since the upgrade to Android 6.0.
Finally, I unlocked the bootloader and used Emma to downgrade to 5.1.1 (Emma did not propose a firmware with the right customization but after installation I was able to configure locale parameters to match my region).
Not a single shutdown due to "battery overheating" for a few days, finger crossed.
See https://developer.sonymobile.com/ for instructions on how to do this and to download Emma.
hi
i haved same problema in my sony xperia Z3.
go setting >apps and click three dots on top of the right ,then select the show system
roll down the list then find overheat control app then you click on it .click force stop ....wola .:smileysmileythumbsup:
