I have a *lot* of music! Does anyone know if it's possible to carry out the mood analysis on the PC before it is uploaded to the tablet?
Yeah the analysis does take quite some time so I guess with a lot of music, it would be a pain. I only tried a few songs so far.
No offical tool for it but I know "Content Transfer" had a 12-Tone Analysis feature which looked at your music as your transferred BUT it was usually very specific at the devices it recognised. You may wish to try it out on the link below (from memory, you may need to activate it from the settings before you use it) but I could not say for sure until I try it out myself.
http://support.sony-europe.com/dna/downloads/downloads.aspx?site=odw_en_GB&f=Con_trans13&m=NWZ-X1050
Might try it out tonight.
I use Media Go by Sony.
http://mediago.sony.com/enu/download
Message was edited by: andyrlea
Media Go was actually pretty good but only does basic but much easier to run with the Tablet than Media Manager so good call! I guess if you want to do advanced, it will have to be done via the Tablet itself. Will take some time.
You can analyse an individual track. Play a track and switch to the visualization view. Then select music analyzer from the menu in the top right. I didn't notice any difference to be honest. But I do like the animal theme.
Oh and you can add lyrics too. But I haven't found an easy way to do this yet.
oooh thanks... will try that right now
This is perfect. You've solved two issues for me at once!!
I can sync Favorite Music, and it does it without removing all the ID3 Tag Album Art (like Winamp does...)
AND when it syncs, it does the Mood detection - even if it's called SenseMe (I suspect it's the same thing..!)
T
H
A
N
K
Y
O
U
