Hello a few weeks ago i bought a xperia z2 tablet, i already read the guides and i cant find the data movile access, i need to know how to do it or if the tabelt not support it. thanks
Hi @Nyku
Is your tablet the 4G model ? If it is then try the following please:
1- Tap the Apps icon located in the top-right corner of the screen.
2- Tap the Settings icon.
3- Tap on More.
4- Tap on Mobile Networks.
5- Make sure there's a tick in Mobile data traffic box.
You can also check you're connected to the right network by pressing the network operators option at the bottom and selecting the right network.
Make sure that "IFF" you have the LTE version that the data it's on, settings > data usage > enable data
is the sgp512 32g, in the store they sold me this tablet asi if could connect tu 4g......... so i will go back there thanks XD
