Keep getting 'screen overlay detected, go to settings, apps and turn screen overlay off. I have turned this off on every app but, it has made no difference. I can no longer use attachments in email and turn on storage permissions etc.
Hi @Maximblue,
Does this message appear when starting a specific app? If so, does that specific app have all the latest updates installed?
@Maximblue Do you have clean master installed? Can you check if the same occurs in safe mode?
This appears when using email forwarding or attaching. I have just completed the Sony update. The email was perfect before that. I am using a Sony Xperia Z3 compact tablet. Had it for over a year and it has been perfect.
Hi @Chelly,
If this does not happen while in safe mode then it is caused by a third party application in your phone. Unfortunately you cannot see exactly which one it is. I would recommend that you start by updating all your downloaded apps, should that not help you will unfortunately have to uninstall your downloaded apps in order to try and find the one that is causing this to happen.
