Help - I seem to have lost the + that should be on the top right of my screen - similarly a long hold on the screen doesn't work either.I guess I may have tweaked something in error can anyone help me to sort it out
Thanks in advance
Hi judypolarbear,
This disappeared with the ICS upgrade. The procedure is now..
To change the wallpaper tap and hold on the screen.
To add a widget open Apps and then hold on the application you would like to add to a home screen.
To add a widget, open Apps and then click widgets on the top left cornerr.Tap and hold on the widget to add it to a home screen
Rich
Hi judypolarbear,
Rich
