- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
December 2011
December 2011
Loose Screen??
I have noticed that when I tap on the right hand side (in landscape orientation) of my Tablet S screen it appears to rattle as if something is loose inside?
Also if I give the tablet a light shake , something rattles inside
Could any of you advise if this is the same on your tablets , or have I git a bad unit?
thanks in advance
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
December 2011
December 2011
In my opinion, this is not normal; you should perhaps return it...
Ce message a été modifié par: bennybuche
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
December 2011
December 2011
mine creeks in various places but doesnt rattle or screen is loose. return it asap as the longer you leave it the more chance of sony saying you damaged it as they would say why didnt you return it immediately. also the fault could develop.
