x
djtaz007
Visitor
keyboard bkb50
hi,
I receive my tablet Z4 with the keyboard, but how do i connect then?
thanks.
22 REPLIES 22
The_Alias
Visitor
Thanks, that worked for me as well.
wfinley
Visitor
Hi, on the Z4 tablet, the BKB50 pairs and connects just fine.  After the initial connection it works until a timeout period of a few minutes.  Then the only way I can get the BKB50 to work again is to turn off/on bluetooth on the Z4 tablet where it works until the next timeout.  Is this normal behavior?
Other bluetooth connections on the Z4 seem to be stable.
I've tried doing a hardware reset on both the BKB50 and on the Z4, but it doesn't change how the BKB50 behaves.
The Z4 and BKB50 are at the latest Sony firmware.
Power cycling the BKB50 doesn't restore the connection.
Manually trying to reconnect the BKB50 from the bluetooth settings screen shows the BKB50 in a "connecting" state.  It stays that way until I turn off the bluetooth on the Z4.
Ub119
Visitor
Having the same issue with the keyboard, the only way to get it back is to turn Bluetooth off and back on, is there a fix for this?
