x
profile.country.da_DK.title
plysgaard
Explorer
Internal Storage?
I have just bought a 16GB Sony Tablet S, and in my file transfer app it tells me that I only have a total of 8.9GB memory...
Is the system really taking up 4-5GB?????????
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
reg6ft3
Explorer
About 5gb is reserved for apps and system files by android, it is still there, but you can't use it for other stuff. I got a 16gb sd card for cheap, you can get up to 32gb if you require more storage for media, pdfs, music etc
2 REPLIES 2
reg6ft3
Explorer
hip_hop_rob
Explorer
Additionally, you can get an OTG(on the go) micro USB to female USB lead for about £10 and connect USB flash drive.  That way you have the portable convenience and the flexibility without the extortionate increase in price that Sony are demanding for storage on the go!  And it is swappable memory too-Can't get any more convenient than that.  IPAD users where's your convenient mobile storage?
