Hi all,
just to let you know that the ICS update has been released & is available to download now..:smileyhappy:
well done with adding the mail, but then whythis wasn't included in the first was a bit of a puzzler to me. does anyone know how, or indeed if at all possible, to change the automatic shortcut touch at the bottom of the screen layout? I would like yo be able to add my own regularly used shortcut as opposed to those provided.
Found that that the seeded keyboard does not work with
Chrome Beta, whenever I type anything it gets duplicated and if I use the
backspace key it all gets duplicated again.
I haven’t tried downloading another keyboard and seeing if that makes a
difference.
To try this open Chrome and say select Google Search, start
typing into the search field and then use the backspace key – what happens???
One of the features of ICS was the ability to disable apps
you did not want to run. It seems that
this feature is missing from the Sony build of ICS, I wanted to disable ‘Reader
by Sony’ which always seems to be
running but when I went to disable it the only options I had were force stop
and uninstall updates, no disable option
Anything else missing??
I'm using the default keyboard in Chrome now with no issues. Thumb Keyboard is still my keyboard of choice.
PS How good is Chrome?! nme.com doesn't scroll like a pile of crap anymore!
Matt
What's the deal with the Widgets tray's white background though? Is that a Sony thing? It makes white widgets, like the analogue clock, almost invisible. See attached screenshot.
Btw, native screenshotting is awesome!
chrome is no good. doing some benchmarks on it, its quick, about 20% faster than the already fast stock browser and even faster than the ipad 3 browser but it just feels jerky, glitchy etc + no flash.. not a huge fan of the app screen. not sure why they couldnt allow to use the live wallpaper as the background to the app screen. and the small apps ir control needs work, needs more buttons.
The accessibility features of the new stock browser are excellent.You can now override websites that have disabled zoom!
i have Updated the new Firmware after its restarted it give me an "error code0" and now i couldn't find any Sony applications and build number "Unknown(US) . what should i do . i have done the factory reset as well. but nothing change .
please help me.
