- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I accidentally turned my tablet into safe mode and now i tried restarting it and its just back to safe mode all the time. I restarted it , turned off and on , tried turning into safe mode again and then restaring turning off and on what to do???
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's back to normal. I turned it off and started charging it.
I dont know what could cause it tho
Thanks for help tho.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This can be caused by a defective volume down button. Could this be the case?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My volume down key works properly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you tried a software repair lately?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Curnow1,
That is odd. Could you test the volume keys in Diagnostics just to make sure that they pass that test as well? You can find Diagnostics if you go to Settings > About device.
If it works properly in Diagnostics as well then you should go with Alexdon's suggestion and try software repair using PC Companion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Glad to hear it's back to normal never the less.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
