x
How to get a new charger
SOLVED
profile.country.en_GB.title
vaugrat
Visitor
I need to buy a replacement charger but the Sony site says that it is not available yet! appears somewhat strange. Any ideas?
1 ACCEPTED SOLUTION
Accepted Solutions
iawilso7391
Visitor
the cradle doesnt come with power cable but I do know u can get power cable from sony centre shops
3 REPLIES 3
profile.country.no_NO.title
Huey-Norway
Visitor
I'm not sure if the cradle comes with a power cord but that would be worth checking out.
iawilso7391
Visitor
Watashiwateshdes
Contributor
Most likely because the unit is still very new. Accessories are slowly being launched so hopefully see this available soon.
You might also want to try Nedis although they may charge a bit more than other places but may have it available already. Their site seems to be slow so not being able to check. Just let them know your model and they should be able to pull it up.
Nedis - 0871 222 9333
http://shop.semenedis.com
