hi,
didn't we have a house (home) icon on the previous android version?
godzilla
Hi godzilla11
To look on the positive side you can of course create a shortcut to your home page which serves the same purpose.
Rich
Yes we did.
well, I want it back please!
Ah right, I see. You want it back do you!!
Well you can't
