All of a sudden my Tablet S won't switch on properly! I starts the process and can't get past those swirling lights that show at start up! It will stay on them for hours and not go any further!!!
Have you guys any ideas??? Please someone help me!
hi haveing the same problem hours of swirling lights!!!!! any help please
same problem!!
so i let the tablet run right out of power reset with small pin let charge for 15 mins or so then turnd on with volume up buton held down. the tablet came on but said luncher had stoped as well as other things that it said allso stoped maniged to do factory reset. so far all is now well hope this helps.
