I'm using a Tablet S, my earphones arent responding since ay ear. I've tried several fixes mentioned on this forum: smart connect, soundabout, reset..
Can someone help me?
Since i downloaded smart connect, it gives a very weak sound trough my headphonea. So I think it might be software?
Yup, I experience the same issue. Does this mean I need to take it to a repair shop?
