Is there a reason whay the Tablet Z doesn't have a reboot option in the power menu? The other day I was in a local phone shop testing Xperia Z3 compact, and to my surprise this model sports a reboot option.
There are cases where a reboot would be quite handy...
Just like Thommo said, some of the phones does not even have this feature. The functions may vary from product to product, but I will forward this internally.
The reason is it probably wasn't a feature of the Tablet Z but is now on newer devices - Not even the Z1 Phone has it unless you were to root and install an Xposed module like I have
@Thommo: ok, I thought that was a standard in Android (see it on my old HTC and maybe a few others), so my assumption was wrong; sorry.
@Hampus: really would appreciate it, many thanks
