Hi. I can connect my Tablet S to the exchange 2010 server on my LAN by using the internal IP address and the built in mail app.
When I try to connect from outside the LAN using the address that is forwarded to the server, the Table doesn't find the server.
I can however connect from outside by using Touchdown for Tablet.
I would prefer to connect using the built in application as that also does POP addresses which Touchdown does not.
I used the same setting for the built in app as for Touchdown.
I have 2 servers on my LAN and so the exchange server isn't on the ususal port (433) but is on 4433.
If anybody has any tips I would be grateful.
have you tried to add the port to the ip adress?
xxx.xxx.xxx.xxx:4433
I have 😞
I have tired with the IP alone, the IP with port number and I have a remote suffix on the domain that points to the IP with port.
ok
as a check: you are running the latest update on your Tablet S (Android 3.2.1 release2) right?
Yup - latest release.
hi
did you solve this one, have the same problem.
Thanks
I did. I solved it by letting the SBS server running exchange have the default settings and changed the port number on the othe server. It now works.
hi
would you mind explaining in a bit more detail, what are the default settings and which port did you open
thanks
sbs 2003 & exchange server
