Is there an update for the music player? the ui on the equaliser is messed up. I tried rebooting and cleaning the memory of the music app.
The fader on the clear bass is not alligned. Please see screenshot inserted.
@uliwooly, hi! I tried repairing it via computer thru this xperia companion app. It did not worked at all. I'll elaborate the bug the best that i can. On the equaliser there are 6 with faders. 5 is on vertical and 1 is on horizontal and that's the clear bass. And each fader has level markings. But on my equaliser, the clear bass fader is separated on the bar on portrait mode. Fader adjuster is on top and the bar is at the buttom. Just like removing a train on it's track.. One thing more, the remaining 5 faders was move on the left.. Picture it just like inserting another fader leaving a space on the right side.
I've noticed that my Z3TC, also running Android M, has the same bug as you.
Yes it does line up when rotated to landscape mood @uliwooly
