Hello,
I've tried to enter any code found in the forum to disable the retail demo app.
But it didn't work !
Anyone know the right service code or procedure to disable this mode on Z3 compact tablet WIFI
Thanks in advance
Regards
Arnaud
yes, I tried this code and nothing
Regards
Arnaud
Do you have a demo device - Dial *#*#7378423#*#* then open Service info then Software info and reply with the customization number
My Bad ...entering the code did work after all
I've done it at least three times. I don't know if I mistyped it before or something else ...
Anyway after entering the code correctly, the Contacts Apps closed (it didn't the previous attempts) and the retail demo do not appear anymore when charging...Great !
Arnaud
PS : On a WIFI tablet, to make the dialer appears, refer to this post :http://talk.sonymobile.com/t5/Xperia-Tablet-Z/Retail-Demo/m-p/325563#M117
I installed a 3rd party dialer app from the play store which works just as good
Well, even if I manage to disable the retail demo.
The customization number is : 1290_0438_R3C
Regards
Arnau
So according to my list the latest firmware version available to you is 23.1.A.1.28/R3C and you have the Frech Generic firmware
