Anyone else having issues with crackle? force closes all the time for me. uninstalled from market and re-installed sony version of crackle but still same problem?
Thanks for the update Padster.
Rich
Bit more of an update...
They will be releasing an update to the sony crackle app
I've asked if there is a date.
Regards
Padster
UPDATE : They've just released an update a few minutes ago - Crackle wasn't working but after the update is again - I'll keep you all posted.
Regards
Padster
how did you get the update?
Via my apps then manage
Or you can go to the android market open and update
regards
padster
