When I try to open Chrome, I get the following message:
"Critical functionality required to run Chrome is missing; either your Chrome installation is incomplete or not compatible with this version of Android."
Though I do not know what, some type of update ran a couple of days ago however, I have used Chrome several times since the update. Perhaps some other update automatically ran without my knowledge. I also have Lumosity installed and I am getting a message that it has stopped also.
I tried restarting but it did not resolve the issue. Any assistance will be greatly appreciated!
You could try opening Settings then Apps and swipe to All then locate and open Chrome and tap on Force stop, Clear cache and Clear datat and reboot and test if that fails then follow the above again but this time tap on uninstall updates from the upper right corner and reboot and test
Thank you so much! I had to uninstall the updates and I'm now able to access Chrome again. I truly appreciate your prompt and thorough response.
