hi,
since the last update to built: 32.3.A.0.376. it impossible to charge with my charger.
Best
What happens when you connect your charger?
Do you use the original Sony wall charger included in your box?
when i use the charger the screen is turnning on, but no charge.
I try with 2 different chargers sony with different cable, and nothing.
I can only charge with my PC.
it's the same thinght
