Hi, I'm new to all this technical stuff so bear with if the answer is simples.
I turn bluetooth on my tablet and my nokia mobile, they pair, but when i press connect on the mobile it says service not supported by other device. I can't find a connect link/button on the tablet, anyone have any ideas, thanks Mel
Hi. What's the model number here? Might as well check the specs first and verify.
Hi, sorry its a SGPT114GB
you need to download an app like Bluetooth File Transfer
once the devices are paired by android, a bluetooth app should be launched to start a connection.
