is anybody else having issues with setting up a generic bluetooth keyboard ?
cant seem to use it after it has been paired. works fine with my tv and pc.
I have a no name bluetooth keyboard from hong kong no issues here
I had no problem with a Logitech diNovo Edge.
Once paired, you have to accept the keyboard in the Settings menu of the tablet (a security thing... so nobody can take over from a distance)
are you aware of that?
there is an app on the market called external keyboard helper pro this may help you
