I also have this problem - the track pad works, but can't get the keys to work either. I've tried resetting it and the tablet, so I think it's an update issue. Hopefully this can be sorted soon. Anyone else have this issue?
I also have the same problem. My keyboard worked perfectly until I updated my Z4 tablet. Help?
Sorry to hear you're having the same problem.
I tried to reset the keyboard, the tablet, everything. I did a factory reinstall on the tablet too, but nothing. I connected the keyboard to my phone, and again the touchpad worked but not the keys. I tried to find a way to roll back the driver on the keyboard, but couldn't see an obvious method.
After speaking to Sony's tech support, I've sent it to them to fix. I'm sure it's a software issue, but they couldn't sort it remotely, so hopefully they'll sort it.
Good luck,
Olly
Did you get it solved?
My Xperia had the same problem, i made a factory reset before sending it to Sony Repair Service, with no result. The note says they made a software update, off course after factory reset, and the guy at the store test it for one day without problems, but after getting it home and reinstalling everything the problem appeared again.... I am fed up about this. It worked perfectly during one year, and suddenly, software update and everything went wrong.
Anyone of you got it solved?
Thanks
could nt reconnect my bkb50 although it was paired
noticed I was in flight mode (my bluetooth and wifi were on though), disabled flight mode and could reconnect my bkb50 again ! happy again !
Then connect to bluethooth again.
