Will the BKB50 Keyboard function normally including the Windows style taskbar is the Xperia Z4 tablet is running CM13?
Hi @RobD1001,
Welcome to the community.
Unfortunately, we cannot guarantee the functionality of our accessories when used with modified firmware.
Is the Windows style software part of the keyboard or the tablet please?
The keyboard launcher is an application that opens when the keyboard and tablet are paired and connected. I am not sure if this is compatible with non-Sony firmware however.
Is the application included with the tablet? Or is the application installed FROM the keyboard onto the tablet?
It's installed when you pair the keyboard from the keyboard. It's not downloaded from places such as the Google Play Store, if that's what you mean.
I know that it is not downloaded. I would like to know where the application is installed from please? The tablet or from the keyboard?
Thank You
