ВЕТЕР
Visitor
battery
Здравствуйте, скажите аккумуляторы на планшетах сони таблет все одинаковые ? Мой надо заменить.
Hello, tell me the batteries on the tablets Sony tablet are all the same? My need to replace.
gT
1 REPLY 1
Jonas
Master
Hi @ВЕТЕР, welcome to our forum!
I have translated your question to English as this is an International forum.
If you need to replace the battery in your Xperia Z2 tablet, I would recommend that you get in touch with your Local support team so they can arrange a repair for you, or give you the address to the nearest authorized service centre in your area.
I hope that helps! Slightly_smiling_Face
