Updated Z3ct two days ago and since the apps I've moved to the SD card don't load on the home screen. I'm using the stock launcher and haven't had an issue before. Any way this can be solved???
There are reports of this and unfortunately it is a result of being able to move apps to SD:
/t5/Software-Updates/Latest-software-update-removes-apps/td-p/1048755/page/2
