hi
where can i get a replacemnt charger for my Sony tablet S. i am dissapointed to say the least with Sony as they have not made thier accessories for experia compatible with the tablet S
Hi moh_tiger,
do you mean the original Tablet S (SGPT111 - SGPT114 series) if so the part number is SGPAC10V1..
I suspect these will be hard to come by now..:smileyworried:
A few options, you could try your local Sony Centre, they may be able to source one for you, or try the Sony online store & see if they have any available - Call 0207 365 2413..
Failing that then try Sony Support - Contact Sony support
If they can't help
then I guess searching the net to see if any are still available..
