Is it possible to by extra 3G USB modem for Sony Tablet S? Is it something work with Sony Tablet S? Thank you for answer.
if you want 3g on the wifi version and have internet on your mobile. just download a mobile hotspot app and connect your tablet to it using wifi, thus using your phones 3g.
that is what I do and it works perfectly fine.
Hello, yes I know, but problem is that I use APN conect to company exchange server and is possible conect just with 3g. So can not conect with Wifi than just with mobile 3g.
