It can be done but this is not the proper forum. XDA forums talk about it, but the tablet needs to be rooted which is not that big a problem as it was years ago. But, if one does not know their way around a fully rooted system, a "bricked" tablet is always a possibility.
I have to agreed the tab is terrible to use.... even when clicking a icon there is a delay between the touch and the icon animation .... need upgrade and fast please......
I am with you guys on this it is really awful slow and very laggy, is there some way to roll this back to something that actually works?
I've just disabled HW Overlay to get rid of the horrible screen flicker, and strangely this seems to have had a really positive impact on the performance...much smoother, faster,could still be better - still have laggy moments, but a definite improvement.
This is basic stuff Sony...
yes and I also Force GPU rendering help scrolling down and up.... noticeable with the settings menu....
While these fixes do work, just remember that they are not permanent. If you shut your tablet down all of these developers options will revert back to their default. Unfortunately….
Don't worry, most stay stuck. The HW Overlay fix that stops the screen flashing defaults back. And that is the key fix......dang.
