Hello, I'm interested in buying a car subwoofer with an enclosure, it's the XS-NW 1202 E, 420W RMS, 1.8kW peak. Obviously I need an amplifier for it but here's my question; I'd like to amplify the sub but also my speakers (2x 100W RMS Hertz on front and 2 75W RMS Audisons midwoofers in the back) with it. I'd like to use a Sony amplifier with 4 channels. What would be the best choice for my needs, that would decently and safely amplify the sub and the speakers? Thanks!
Here's the sub spec sheet: https://www.sony.ro/electronics/subwoofere-auto/xs-nw1202e
Hey,
I'd suggest that that best model for your setup is the Sony XM-6ES 6-Channel amplifier. You can connect your subwoofer on bridged channels 1 and 2 for 330W RMS power output, and connect your Hertz speakers on channels 3 and 4 for a 100W RMS power output, and then connect your Audiosons to 5 and 6 channels (and make sure to lower their gain a little bit because they output 100W RMS and your speakers are 75W RMS)
I hope that helps
