I would like to know if other people encounter the same issue. When I use bluetooth streaming or USB connection I have sound on the car speakers only if I switch the AF (alternate frequencies for RDS radio) on.
Did you already encounter this kind of issue ?
Thanks a lot.
Regards.
A french L77BT user.
Guess you have an amp installed?
If so, you used the power antenna connection instead of the amp remote connection at the rear of the radio.
