I recently upgraded my iPhone to version 4.3 (8F190) and it is now incompatible with the 4 month old XNV-L77BT Sony unit. I called technical support to ask when there would be a firmware release to address this and they denied that there was any problem, stated that the unit only supports the original version of the software for the (in this case) iPhone. I pointed out that if I purchased an iPhone today and a new Sony unit the two would be incompatible and that there was no version number specified under the compatibility section of Sony's website. They then tried to say that if I bought a new iPhone it would not have the most recent software version and would therefore be compatible and that it was the fact that I had upgraded software on the iPhone post installation of the XNV-L77BT that was causing the problem.
On the whole, an appalling customer service experience. I was going to upgrade my Kenwood unit in my other car to the Sony. The Kenwood is much less user friendly (and the Garmin navigation is not as good as Sony's TomTom) but the difference in support is amazing. Their people know about issues, understand ongoing compatibility and are able to tell you when fixes are coming. I'm not changing now unless Sony get their act together and am going to review all documentation regarding compatibility to see if I have a case for refund and compensation. What a disappointment.
Has anaybody else come across compatibility issues and have they encountered a fix or, even, more helpful responses?
I have the same issues & got same responds from tech support, I'm using a iPhone 4s. UI is the worst I've ever used, I have revised this on reevo and suggested a UI update, feel very disappointed with songs responses, they have just taken the money and run. Would I recommend Sony products again, basied on this unit NO. If I would not lose a lot of money selling this I would have somthing different in a flash. Maybe the more complaints posted might make Sony think about a update to sort the issues. (tomtom side is great)
