What causes this issue? How to fix it ?
It’s happening suddenly, doesn’t matter If I listen the music or not, l it also happen when turn it on and trying to connect my device during standby.
Hi, it is probably the noise canceling mics are trying to sense the outside noise, check if the noise canceling mics are covered or if you're wearing the headset correctly from this link
You can also check if the headset is running on the latest software version here, after that you can try to reset and then initialize the headset if the issue is still there and then test it. I hope this helps
