Hi, is there a way to completely turn Bluetooth off on these headphones while still using noise cancelling? For example, if the wire is plugged in, can I use noise cancelling but have Bluetooth completely turned off? Thank you!
Bluetooth is in sleep/standby mode when cabled, and you can use NC.
Thanks for replying, does that mean Bluetooth is off or on?
