My PC is a home build with Asus motherboard with inbuilt bluetooth. They pair after about 3 or 4 attempts then connect, but just disconnect after 30 or 40 seconds. My PC site just next to my legs on the floor.
They work fine with my iphone and ipad.
So not sure on the problem, any help will be appreciated.
Hey there,
I would say try to follow this based on the operating system you're using: https://bit.ly/2XD3P5Y.
If it's the same, try it after you initialize the earbuds: https://bit.ly/3PVt0HA.
Hope it helps.
