I have a pair of WH-1000XM3s, is there any way to connect these to my windows 10 PC using the LDAC codec?
It says on the Manual that it will work with devices that support LDAC, I've read that Windows doesn't support LDAC codec, your phones might do. You'll also need to adjust the “Priority on sound quality” mode, which can only be done using the "Headphones Connect" app on a phone.
