Hi my DAB700U is saying my ipod shuffle 1st gen is not supported in usb anyway of fixing this
Thanks
Hi and welcome to the forum.
Looking at the compatibility for iPod products, quite a few are supported by sorry to say the shuffle are not listed.
http://www.sony.co.uk/support/en/product/CDX-DAB700U/compatibility
Rather that buying a whole new iPod, you could just use a USB flash drive and load your songs on to that instead as this product does support m4a files which is what iTunes usually uses.
I hope that helps.
