How do I connect to 2024 SAMSUNG smart tv with no optical port or headphone jack .it has 3 HDMI ports one with eARK is there an adapter available
Hi @Intcol,
the image is a bit blurry - can you help me out with the model number?
I would like to verify wheather it really has no optical output.
- Nic
Hi @ Ian Nic. Samsung 43” smart TV DU7100KXXU 2024 model
Hello @Intcol,
color me surprised, but it seems, that Samsung really got rid of even the most basic outputs as per the product specs on the TV models website:
There seem to be a few "ARC audio extractor" adapters available, but as I never used any, I can't recomment any particular product or tell you how well they work.
- Nic
