Can anyone please tell me if this unit fits in a Saab 93 2001 and what cables are required also will steering controls work?
Message was edited by: speedyest1
Hi There,
If you go to the halfords website and search for the sony xav 601bt and add it to your basket then you will need to click "will this fit my car" and from there you will choose your car make and model and then it will show whether or not the stereo can fit the car and what extra adapters ou need to purchase to install the unit
Hi There,
