MY SONY NWZ B152F is not working properly. It has a problem with hold button. It always shows me that the device is in hole alwaya the switch is in either hold or not hold...i cant use it ,,whai do i do??
@thedebasis Hi and welcome to the Community.
I don't have a specific answer for you, but did you try resetting the walkman?
(Although this will delete your music etc. on there)
